bogging problems
Old Jul 31, 2004 | 11:51 PM
NBsportsman's Avatar
Default bogging problems
What are the odds of that. Two posts, same answer, exact same time...
Old Jul 31, 2004 | 11:53 PM
yammaslamma's Avatar
lol....well they SAY great minds think alike...sooo yeah
Old Aug 1, 2004 | 12:02 AM
Jayblazer's Avatar
my 250 does that on hot days when i have been hard on it i normally just let it cool down then when it starts it seems like it wants to die and if i get on the throttle hard it will so i normally build the rpms real slow and it seams to wake the moter up and then it will run fine oh yea it only does it after i turn it off and then try and turn it back on....and only on hot days
Old Aug 1, 2004 | 01:15 AM
midwest's Avatar
Before you change your carb settings, I would make sure that the carb is clean. If this problem just started happening, then I would assume thats the problem. If your jetting was fine before, then something happened to cause this problem. Make sure your fuel line and filter are free flowing, it sounds like the carb is starving for fuel.
Old Aug 1, 2004 | 01:17 AM
  #15
i had it narrowed down to that, or starving for air..one or the other.
thanks for all the help guys.
Old Aug 1, 2004 | 01:23 PM
  #16
well i went out this morning and took it apart and my needle actually came up out of the hole....has that ever happened to anyone else?
but anyway i got it fixed and im recharging my K&N as we speak so once i get that back in i'll let u all know how it runs
i also lowered the clip one notch.
Old Aug 2, 2004 | 01:20 AM
  #17
My Sportsman started to bog on load about a week ago same time we got some real hot muggy weather. I moved the clip up two notches on the needle and now it's ok. I am now thinking about rejetting...
scram5050
Aug 30, 2024 01:39 PM
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Sjrpp
Jul 5, 2015 09:04 PM
