HELP CHANGING PRIMARY CLUTCH SPRING
Old Aug 2, 2004 | 02:40 AM
TJCINC's Avatar
Default HELP CHANGING PRIMARY CLUTCH SPRING
DOES ANYONE HAVE A WEB SITE THAT SHOWS HOW TO REPLACE THE PRIMARY CLUTCH SPRING IN A 01' 400 2X4 SCRAMBLER ? AND IS IT THE SAME FOR A 01' 500 4X4? THANKS FOR YOUR HELP.
TOM
Old Aug 2, 2004 | 02:41 AM
MnFriesen's Avatar
do a search on the forums and you should run acrossed something about it...
Old Aug 2, 2004 | 04:09 AM
BigBadScrambler's Avatar
Its very simple. Just remove the 6 bolts that hold the cover onto the primary clutch. Before you do that mark the cover so that it goes back on inthe same position as it was taken off. There should be an "X" already, but mark it to be certain. Once you get the bolts out (remove them in a criss cross pattern), then the spring will come out. Put the new one in, and reinstall the cover in the same position it came off. Tighten the bolts in a criss cross pattern and torque the to 90 in. lbs. That simple. It is the same way will all the polaris ATVs
Old Aug 2, 2004 | 07:57 PM
fishslab's Avatar
You have to remove the center bolt as well. I thinks its a 5/8. When putting it back together retoque this one to 40ftpds.
Old Aug 2, 2004 | 07:59 PM
scrambler123's Avatar
It is very simple as the others have stated. be careful when torquing the small bolts i broke one off last time [img]i/expressions/face-icon-small-mad.gif[/img]
ghost civic
Jan 15, 2020 07:43 AM
merryman
Jan 19, 2016 04:29 AM
ghost civic
Jul 27, 2015 03:15 AM
coolguy420
Jul 10, 2015 01:17 AM
Wnthunting
Jul 9, 2015 03:02 PM
