jackshaft??
Old Aug 2, 2004 | 02:43 PM
CED's Avatar
CED
Default jackshaft??
Yeah we kep the same ratio that the tranny had.I think it was a 10 at the top and a 26 at the bottom,that way we could run regular sprockets front and rear and not a 70 tooth rear which is what would happen if you used a single shaft setup.
Old Aug 2, 2004 | 02:47 PM
scrambler123's Avatar
Default jackshaft??
yeah that makes sense. On the top shaft do you think i could get away with weighting the right side of it somehow rather than making than having it stick out there? or would the shaft not be as stable that way?
Old Aug 2, 2004 | 02:50 PM
CED's Avatar
CED
Default jackshaft??
The shaft in the pic's that i sent you was cut after everything was lined up.
Old Aug 2, 2004 | 02:51 PM
Default jackshaft??
what kind of bearings did you use?
Old Aug 2, 2004 | 03:33 PM
  #15
CED's Avatar
CED
Default jackshaft??
Heavy duty hanger bearings.The motor has over 160hp.
Old Aug 2, 2004 | 03:52 PM
  #16
Default jackshaft??
any reccomendations for the kind of bearings i should pick up for mine?
Old Aug 2, 2004 | 03:55 PM
  #17
CED's Avatar
CED
Default jackshaft??
The guy i built the bike for picked up the bearings.You need to make sure they will fit the shaft.
Old Aug 2, 2004 | 03:57 PM
  #18
Default jackshaft??
ok thanks
Old Aug 2, 2004 | 04:01 PM
  #19
Default jackshaft??
you wouldnt happen to have any pics of an a or j-arm conversion would you? [img]i/expressions/face-icon-small-smile.gif[/img]
Old Aug 2, 2004 | 04:25 PM
  #20
CED's Avatar
CED
Default jackshaft??
Not yet.Check with Troyer,he just finished his.
