Need some advice please
Old Aug 2, 2004 | 08:03 PM
kysupestar99's Avatar
Default Need some advice please
ok, i got a 2004 330 polaris magnum. i bought it in february. It has 400 miles on it. It has been in the shop now 5 times. what it is is i will be driving along in high gear and approximately 20 or 25 mph more or less. i will go to slow down and it will just die and then it will backfire. also this 4-wheeler doesnt hardly want to start. it will grind a few seconds and then maybe it will start and maybe not. then i try again and it will eventually start. i am getting so fed up. i am paying money for this new atv and it preform this way. if anybody has went through this i need to know what my options are. is there a lemon law on a atv in kentucky. am i stuck with this atv. will polaris do anything if i call them or is it up to the dealership. want to do something tomorrow if i can.
Old Aug 3, 2004 | 01:43 PM
jimmypsp700's Avatar
are you sure your using good gas? not trying to be a smart a**, just trying to help. Sounds like a carb problem, possibly the float.
Old Aug 3, 2004 | 02:50 PM
yaK's Avatar
yaK
I'd check the plug wire...seems I heard of more than a few that were routed wrong and were getting pinched between gas tank and the frame!
Old Aug 3, 2004 | 02:54 PM
lovemud's Avatar
Does that model have the etc throttle? if so make sure it's adjusted correctly.
ultangler
Nov 30, 2024 01:35 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
kodiacrunner
Oct 4, 2015 11:52 AM
wrencher82
Sep 28, 2015 10:02 PM
