Trail lightened fly wheel
#36
It doesn't take long to do. Make sure he uses coolant. If you get it to hot the glue holding the magnets will melt. Knock your gear ring off and true up to the turned diameter that the ring was on. I used a backing plate so that I could tap the back of the fly wheel against it to make sure it was square with the chuck. True it up to within .0005 and cut away.
