Silent chain in transmission
Old Aug 7, 2004 | 09:38 PM
bisho12's Avatar
Default Silent chain in transmission
I jut took the tranny out because it was popping. I found ou t that the silent chain is loose and stretched. My question is has anyone had this problem? what did you replace? just the chain? the gears still look good and i did not run this long with the problem. I took it easy on it till i got home.
Thanks for the help
Old Aug 7, 2004 | 10:13 PM
ftwflh's Avatar
I have had it a couple of Polaris.When you get the chain out check the shift forks and gears for wear.Most of the time you can get by with just a Chain.You run one loose too long and it will bust your tranny .
Old Aug 8, 2004 | 11:08 AM
bisho12's Avatar
Thanks,
When it started popping i parked it. I had to get it home but i did not run it hard i took it nice and easy. the gears look good no visible sign of wear. Im going to replace the chain and the seals.
Any place goood to get these parts? I checked ronnies.com and parts land. but is there a better place?
Old Aug 8, 2004 | 08:40 PM
ftwflh's Avatar
I just get mine from my local dealer he keeps stuff like that in stock.
Jeff Roper
Feb 1, 2022 11:48 AM
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
mrtidy
Feb 3, 2016 05:00 PM
r1pilot83
Sep 27, 2015 07:38 PM
WilliamBos
Sep 22, 2015 04:07 PM
