Replacement Scrambler Rims
Originally posted by: MNScrambler
I am getting some conflicting info as to the size and offset of the STOCK wheels on my Scrambler 500 4X4.
ITP says:
Front: 10X5 3LB+2 4/156 PART NO: T154152
Rear: 10X8 3+5 4/4 PART NO: H184400
And it doesn't look like I can get all four in the T-9 Pro Series. Only the fronts come in the Pro Series, and the rears are just the T-9's. So they won't match.
I e-mailed Douglas and they mailed this back to me.
"'95-'04 POLARIS SCRAMBLER 500
FRONT: 10X6 4B+2N 4/156 PART NO.: 014-19 [.190] = $66.78EA
REAR: 10X8 3B+5N 4/4 PART NO.: 005-07 [.190] = $69.00EA
*YES THE STOCK LUG NUTS WORK WITH OUR WHEELS."
Which wheels can I get that will be EXACTLY the same dimensions as the stock wheels. I don't want them to stick out any further than the originals. Also, will the original lug nuts and valve stems work.
ITP says:
I am most interested in just finding out if the difference in size of the T-9 rims will change the overall tire size and affect the four wheel drive system. Also acording to what Polaris told me for the stock offset, the fronts are 2 1/8" to the outside and the rears are 5 1/2". To me this sounds like the ITP's would make the machine more narrow. Would I notice any handling changes.
