Submarine
Old Aug 28, 2004 | 11:10 PM
Justmessnaround's Avatar
Default Submarine
Help if you can. I have a 2001 500HO Sportsman and the other day a few of us were messing around in a water hole and I got a little to deep. Well after it was pulled out I checked the oil, air box had a inch or so of water in it drained that then I fired it up, and all was fine untill I gave it some gas it runs but I can't get any rpms out of it. What can or should I be looking for?? Thanks
Old Aug 28, 2004 | 11:32 PM
Jayblazer's Avatar
Default Submarine
pull the spark plug out and then run the starter to pump the water out of the head this is the first thing you should have done...hope you dident ruin it..
Old Aug 28, 2004 | 11:36 PM
csamayfield55's Avatar
Default Submarine
make sure you drain the belt housing. Sounds like it filled up with water and you can't go anywhere
Chris
Default Submarine
Sorry should have said that also. I did pull the plug to make sure that there was no water in the cylinder. Also the belt housing has been removed as well.
Old Aug 29, 2004 | 12:27 AM
Whitedog's Avatar
Default Submarine
I once owned a wolverene, that I sunk twice. Both times I had to change the oil 5 times, to finally get all the water out of the system.
Shes alrite, just make sure your good and flushed.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Aug 29, 2004 | 01:01 AM
Default Submarine
OK maybe I didn't say the things that I should have from the start. After my machine died in the water we pulled it out.
1. Checked the air box about 1 inch of water in it and drained
2. checked oil all good
3. pulled spark plug no water
4. drained belt housing
5. started machine (lots of water out of exaust)
6. let idle for a few minutes
7. tried to rev motor but it will not go much above idle.
Old Aug 29, 2004 | 01:12 AM
rmkcac700's Avatar
Default Submarine
if it will idle bit not pull rpm it may be as simple as a damp or plugged air filter. if not that does it pop a bit when u try to accelerate. could be the cam. if it is doing this, pm me
Old Aug 30, 2004 | 02:49 AM
mozy's Avatar
Default Submarine
Drain the carb.
Angel of Death
Oct 18, 2009 09:49 PM
RticKwad
May 4, 2008 02:54 PM
Zoltron
Aug 16, 2003 08:59 PM
Zoltron
Jun 29, 2003 04:36 PM
Taylormade
Jan 3, 2003 10:03 PM
