Carburetor Trouble
Old Aug 31, 2004 | 10:40 PM
ftwflh's Avatar
Default Carburetor Trouble
Originally posted by: Whitewater
What color is your plug? It sounds too rich...have you adjusted the clip?
I've had the same problem with my sportsman 400 carb. I jetted down (150 for my elevation), installed a new main jet (40), installed a needle jet, jet needle, adjusted the air screw, and I raised the clip up 2 notches. The only problem I still have, is it doesn't want to start (cold) not without a pullstart. Damn thing...I give up. Other than that, it runs great (warm).[img]i/expressions/face-icon-small-disgusted.gif[/img]
Anyone have any advice?
Have you check your valves since it started doing this hard starting thing?
Old Sep 1, 2004 | 01:48 AM
BayouBlaster's Avatar
Since you know that it idles fine, then obviously you can rule out the idle adjustment. You now have three more possible things to look at as far as jetting goes on the carb. 1) low speed pilot jet 1/8- 1/4 throttle. 2) needle jet jet 1/4- 3/4 throttle and 3) main jet 3/4-wide open. If you very slowly roll the throttle open and it dies at the slightest movement, then I would check #1 first and then progress your way upward checking the plug at each level. I have an article that can be emailed to ya if you aren't sure what to look for or how to do it. If all else fails, take the carb off, take it apart, clean it well and blow it out making sure that nothing is plugged. Make sure the float isn't stuck either. Before you go so far as to pull the carb off, make sure that none of the hoses off the carb are plugged or crimped. Let us know what you find out.
Old Sep 1, 2004 | 01:50 AM
Sorry, my mistake. Didn't realize that it's a 4-stroke.
Old Sep 1, 2004 | 02:25 AM
Valhalla007's Avatar
That is what I am experiencing. Could you email that article to me, i would definitely appreciate it.
Bruce
valhalla@gondtc.com
Old Sep 2, 2004 | 12:20 AM
  #15
The article is on the way. Check your email. Hope it clears up some of your questions and maybe your problem.
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Ask the Editor
Sep 14, 2015 08:57 AM
