400 xplorer headlight fuse?
Old Sep 5, 2004 | 02:55 PM
xplorer400420's Avatar
Default 400 xplorer headlight fuse?
I just bought a 97 400 xplorer 4x4, well the battery was dead when I got it so to crank it I hooked it to a battery charger on 40 amps, It cranked the motor and I was checking the headlights to see if they worked, well they come on HIGH then went off I switched to low they came on and went off. Now they won't come on at all. Just wondering where the headlight fuse would be located. I don't have a manual and can't find the darn things anywhere. Any help appreciated!
Old Sep 7, 2004 | 08:14 PM
fixed it myself, learned a lesson do not use lights when hooked to battery charger! Blown all three bulbs>
Old Sep 7, 2004 | 08:42 PM
ftwflh's Avatar
Better chech the bulbs on the dash too.Like the oil,hot,nuetral lights along with the AWD light in the button.When you blow the bulbs due to a power surge it will blow ALL the bulbs that were on at the time.
r1pilot83
Utility ATVs
15
Nov 25, 2019 11:39 PM
Whitelx1
Oct 2, 2015 10:55 PM
Lucas Bohanan
Sep 29, 2015 01:16 AM
rockinkgin
Sep 25, 2015 01:52 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
