fuel tank/line fittings 400 Scrammy
What sealant (RTV, etc. ?) do you use for the 90 degree brass fuel line fittings that screw into the bottom of the plastic gas tank. They are leaking, I first replaced the fuel lines that went to the fuel valve (petcock) but that wasn't the culprit. I have heard conflicting info at the Auto stores from soap to Teflon thread tape to certain Permatex RTV sealants (my first thought Black, Blue, Ultra, # 2?) which all do not hold up to gasoline.
Thanks, any info or past experience would be helpful.[img]i/expressions/face-icon-small-smile.gif[/img]
I had the same problem with my o3' 600. I had to take the tank off and replace all the metal foil under the tank, it was saturated with gas. I bought a tibe of sealeant at the dealer that worked well, it was about $18.00 a tube. The RTV does not work.... The new bikes are redignes, this was another polaris slip up..... great!!
bradco
Aug 21, 2015 08:11 PM
juanmortiz92
Jul 21, 2015 04:10 PM
Ask the Editor
12
Jul 21, 2015 06:57 AM
