Re-build 90 trailboss 250 2-stroke. 2x4
Few questions....How hard is it to rebuild this 250? I have the manuel on it. Also I want to bypass the oil pump, as this seems to be the reason I've got a blown motor, what gas to oil ratio should I use? All suggestions greatly appreciated!
ok Where do I get an oil injection block off and what is a single throttle cable? Do I need to just buy the wiseco top end re-build? Man I'am dum... This is my first rebuild! Think I can do-it? Also I think it has been bored before, just waiting until I get it tore apart to tell. One las question.. Can I leave the motor in the frame to do this?
I cant get any info from you guys in the Polaris forum! If I asked about a different quad in a different forum, I would get a ton of info.... Thanks a friggin lot!
Your 250 blazer is a pretty straight forward rebuild . There are very few moving parts in that machine . If you have the crank rebuilt , install new main bearings , and get a fresh bore and piston kit you have a brand new engine .
The oil block off and cable costs about $41 and is easy to find .
Rick
Rick
Thanks for the info! Sorry for being an impacient a-hole. I think I can get-r-dun! I just need to know a good place to order the parts I need.
Go to www.partsland.com. Run a 40:1 mix when broke in. I'd run a 32:1 mix during the break-in period.
