Best mod for trailblazer 250?
I am wondering what would be the best modd without spending to much. I'm thinking either a pipe or a clutch kit. I am planning on getting them both but just want one for now. I am going to get it ported out soon if that helps the decision. I just want something that will make it pull hard and give it more kick.
Also get rid of those stock steel wheels they are heavy. See if you can find some stock Scambler ones they were aluminum on some of the earlier years (98 to 00) might be cheaper than new aftermarket. Yes the bolt pattern is the same. Reducing weight especially rotating weight will help a lot with performance. HTH
