front hub oil
Old Oct 12, 2004 | 09:03 PM
Powerstrokinsportsman's Avatar
Default front hub oil
What kind of fluid does everyone use in the front hubs on their 4x4 scramblers? I read somewhere that atf tranny fluid is the same thing, maybe even better. Anyone heard of this ?
Old Oct 12, 2004 | 09:09 PM
stumpjumper400's Avatar
i use amsoil atf in mine
Old Oct 12, 2004 | 09:13 PM
97RamSST's Avatar
I just use Polaris AGL.
Old Oct 12, 2004 | 10:08 PM
Farmr123's Avatar
You can use any synthetic type F auto tranny fluid.
Old Oct 12, 2004 | 11:11 PM
BigBadScrambler's Avatar
I use Mobil 1 Syn. ATF
Old Oct 14, 2004 | 01:43 AM
tmorris1's Avatar
I know a lot of people use Mobil 1 and Amsoil ATF with good results, but they are not rated Ford Type F. They are a Mercon/Dexron II fluid which is not as sticky as Type F. I don't know how much this matters in this application, but I just thought I would point it out.
Old Oct 14, 2004 | 01:51 AM
From what I understand, if you take apart the hub and remove all the old fluid then the Mobil 1 or Amsoil work great. I have not had any hub problems relating to the type of fluid fluid used. I completely cleaned out my hubs, bearings, hillard clutch. All of it and started fresh.
Old Oct 14, 2004 | 03:08 AM
Snowwolfe's Avatar
These hubs take such a small amount of fluid that you can easily fill, flush, drain, etc a few times to make sure all old fluid is removed.
Old Oct 14, 2004 | 06:41 PM
Yeah. Especially if you buy a quart of trans fluid. It will last years!
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 6, 2015 10:46 AM
toonces
Aug 5, 2015 05:55 PM
carolinabomb
Jul 26, 2015 08:40 AM
tporath
Jul 11, 2015 12:31 PM
