POLARIS 300 STALLING IN REVERSE
Old Oct 16, 2004 | 02:01 AM
DEADDOG's Avatar
Default POLARIS 300 STALLING IN REVERSE
I have a 1995 Polaris 300. It developed a stalling problem in reverse. At first it would stay running if the override was pushed in. Now it also stalls if the override is engaged in any gear except reverse. Sometimes it sputters in reverse and won't move(override engaged)and then may suddenly work fine.I've already checked the switches(override and AWD)by disassembling them and didn't see any problems.Does anyone have any suggestions?
DEADDOG
Old Oct 16, 2004 | 02:42 AM
DGpolaris2346's Avatar
Did you check your reverse limiter? Unplug it and it will probably fix your problem.
Old Oct 16, 2004 | 07:51 AM
ftwflh's Avatar
Unhook the black wire on the reverse limiter and it should be ok but you wont have a limiter.
Old Oct 16, 2004 | 11:49 PM
DEADDOG's Avatar
Thanks guys,I'll give that a try and let you know how it works.
DEADDOG[img]i/expressions/face-icon-small-smile.gif[/img]
Old Oct 18, 2004 | 11:48 PM
DEADDOG's Avatar
I unplugged the black wire from the limiter as suggested,works fine now. Thanks. I may replace the offending part at a later date. Thanks again!
Cole Hadden
Jun 15, 2025 09:05 AM
Reactant
Mar 30, 2022 02:08 AM
maxjung
Jul 13, 2015 05:11 PM
Scottma518
Jul 10, 2015 12:42 AM
bikedad3
Jul 2, 2015 02:15 AM
