Wheel alignment
Old Oct 17, 2004 | 02:10 PM
highwayman's Avatar
Default Wheel alignment
Is there an easy way to do a wheel alignment after changing tie rod ends?
Old Oct 17, 2004 | 07:05 PM
FoxSpirits's Avatar
a peice of string, i know it sounds stupid but it works, and thats how nascar does it [img]i/expressions/face-icon-small-wink.gif[/img]
Old Oct 17, 2004 | 07:11 PM
thewayout420's Avatar
yup,like foxspirits said you can use a piece of sting or a straight edge.i always use a 2x4.
Old Oct 17, 2004 | 08:51 PM
NBsportsman's Avatar
Place two paint cans a head and to the out side of the front tires. Now run a string around the rear tires of the bike and then around the paint cans. If you do it right the string should run about center of the rear wheels and touch square on the rim then out around the paint cans, not touching the front wheels, to complete a rectangle. Center the handle bars then measure from the string to the rear outside edge of the front rim. Measure from the string to the front outside edge of the front rim and it should be 1/8" less. Repeat on the other side and this will give you the proper toeout. Break the locks loose on the tierod ends first and make sure the handle bars stay centered and you shouldn't have a problem......
badgerboy1
Sep 26, 2017 06:11 PM
Oct 10, 2015 10:20 AM
Roro
Ask the Editor
Sep 30, 2015 10:58 AM
tysonbully
Sep 28, 2015 02:30 AM
r1pilot83
Sep 27, 2015 07:38 PM
