Rope Start for 700
Old Oct 25, 2004 | 09:36 AM
  #21
2005BF750's Avatar
Default Rope Start for 700
very good point, it wouldn't.
Old Oct 25, 2004 | 08:14 PM
  #22
longbox's Avatar
The MV700 is carbeurated. I think this is in part to allow it to be pullstarted. Most likely, the system on an EFI would need more power to fire than the charging system could deliver if pull started. This is assuming that you're pulling it because the battery is dead, which would also be a considerable load on the charging system. A pull start is definately nice to have, more for piece of mind than anything else. Jumper cables are a good idea if you're with someone else, if not one of those small booster packs is worth carrying if you're by yourself.
I agree that a pull start may seldom be used. Like your car, or streetbike, as long as you maintain your battery, you shouldn't have to worry. Riding alone is not a great idea anyhow, but if you do I think that a pull start, or booster pack is a must.
Just my .02
Old Oct 25, 2004 | 08:51 PM
  #23
Snowwolfe's Avatar
My new King Quad is a 700 EFi and it has a pull start. A lot of snowmobiles have EFI with 600 and 700 twins and they are pull start only.
Old Oct 25, 2004 | 09:45 PM
  #24
Bill35's Avatar
Good point snow.About a year ago my son was playing with the winch without the quad run well befor i could tell him to stop the battery was almost dead alittle jump and she was up and running but it got me thinking Ive had this quad up in Alaska befor. So if i can put a rope on it i want to.Maybe for a piece on mind.
Old Oct 25, 2004 | 09:54 PM
  #25
2005BF750's Avatar
my 700EFI primed up when I turned on the key, if the battery was dead and it couldnt do that, no way it would start. those snowmobiles must have some reserve power for the injectors or something?
Old Oct 25, 2004 | 10:04 PM
  #26
Snowwolfe's Avatar
Nope......they do not have a battery at all. I have no clue how they work.
Old Oct 26, 2004 | 01:26 AM
  #27
longbox's Avatar
There are a variety of different EFI setups out there. It would make sense that on a machine such as an ATV or sled they would use a system which did not depend on battery power to start, but I don't know what kind of system exactly is used on these machines. Another thing to consider is that in some cases, the pull start will get the engine running, but the battery has some power, just not enough to crank the engine over.
These are just my opinions and ideas as I don't know exactly how this particular system works.
Old Oct 26, 2004 | 01:36 AM
  #28
Polaridoo's Avatar
99.9% you could not rope start the EFI 700 (if the battery was completely dead) Polaris because of the electric fuel pump. When you first turn the key on you can hear the fuel pump cycle on. The snowmobiles (Arctic Cat) that don't use a battery don't use the same style fuel pump as the SP 700 EFI.
Old Oct 27, 2004 | 01:27 AM
  #29
Traildog's Avatar
Here's a thought. The fuel pump could and should be setup to run on a much lower voltage say 6 VDC. Then if the battery is low and not able to crank the engine it would probably still have enough power to run the fuel pump. In this case a pull start would work just fine.
Just a thought.
Old Oct 27, 2004 | 02:39 PM
  #30
silverbullet2005's Avatar
I have not tried it or heard of anyone doing it. It would be a cool mod if you could pull it off at a minimal cost. would be a nice secondary start but to be honest with you I can't see why you would need it unless you plan on your starter wearing out in the middle of the woods.
