700 EFI Front Gearcase Broke
Old Nov 22, 2004 | 10:05 PM
atv73's Avatar
Default 700 EFI Front Gearcase Broke
I was using four wheel drive on my 700efi and got the left front tire stuck so bad it locked up, then I heard a snap. All the other tires were spinning but the left front. I freed it up then it made a sqealing sound and started moving again. Do you think a tooth broke off? It seems to be working right now, but i don't what to do any more damage. Any suggestions. thanks...
Old Nov 25, 2004 | 12:10 AM
CmdrBen's Avatar
Hard to say. Since the right wheel was turning I'd say the gearbox is one piece, and perhaps you broke the hub or axle shaft. Only one way to find out - tear it apart.
Good luck.
Old Nov 25, 2004 | 01:05 AM
elkbow's Avatar
bad thing to do,,,,if you are in bad mud where it is causing suction on the tires, its best to dig it out first and then get the tires moving....this can happen on anything, I did it on my 3/4 ton GMC pickup when I had it, got the front tires stuck in the mud and got on the gas, I broke the ring and pinion gear teeth right off and a piece wedged between the ring gear and front pumpkin cover and punched a hole right through it....
same will happen on ATVs, even worse, they aren't as strong and something will break....the idea is not to let the tires stop spinning and getting to the point that the tires gets suction on it....
not sure what broke, you'll have to either have the dealer analyze or pull it apart yourself...
Old Nov 25, 2004 | 11:08 AM
Polaridoo's Avatar
Were you in high range when this happened? I am getting the feeling that the squeeling sound you heard was the belt burning up. I would think that you would have only heard that if you were in high? Since the front and left side front share the same differential (lock up clutch) and since the right side is still turning, I would say you might have damage the cv joint / shaft somehow. If you are mechanically inclined, start inspecting and taking things apart.
Old Dec 1, 2004 | 10:20 PM
atv73's Avatar
I was in four low and a branch wrapped around tire and I did not know. Shaft feels little loose coming out of gearcase but read it is normal everything else is tight.
STLyamwar
Jul 25, 2020 04:44 AM
ride26
Oct 22, 2015 04:09 PM
TLC
3) General Discussions..
8
Jul 26, 2015 11:09 AM
Peter_
Jul 18, 2015 07:06 AM
jettman
Jul 6, 2015 12:16 PM
