stickers?
Old Dec 5, 2004 | 11:18 PM
Ricke's Avatar
Default stickers?
what is the easiest way to take stickers off the plastic w/o scratching it
Old Dec 5, 2004 | 11:19 PM
espi21's Avatar
Default stickers?
Try using a blow dryer. Heat them up and they should peel right off.
Old Dec 5, 2004 | 11:29 PM
scramblerXrated's Avatar
Default stickers?
pressure washer to get the main sticker off, and goo gone to remove the adhesive left behind.
X
Old Dec 5, 2004 | 11:44 PM
Jayblazer's Avatar
Default stickers?
that blow dryer thing is a pain in the @$$ but it works good..thats the way i did it..
Old Dec 6, 2004 | 02:15 AM
RAJ's Avatar
RAJ
Default stickers?
hair dryer works well.....and so does the pressure washer, even on the stickers you want to keep[img]i/expressions/face-icon-small-frown.gif[/img]
Old Dec 6, 2004 | 07:22 AM
Troyer23J's Avatar
Default stickers?
I used this stuff from ZEP called ZEP OFF. Spray it on, and the stickers bubble right up. Only problem is, You have to get it from a ZEP guy and they have a $35 minimum order.
Stuff also peels paint, so if you use it, be careful.
Old Dec 6, 2004 | 09:32 AM
silverbullet2005's Avatar
Default stickers?
I used a blow dryer to remove all my warning stickers/decals, I did this on the day I brought my quads home. use goo gone to remove the addhesive after the main sticker is gone. I would recommend staying away from the pressure washer idea as to close of pressure can gouge the plastic.
bigred20653
Aug 31, 2015 12:41 PM
chris7420
Jul 30, 2015 02:04 PM
Nondem
Where to Ride
Jul 23, 2015 07:38 PM
psilman
May 26, 2015 09:40 AM
trx430ex
Where to Ride
Feb 14, 2001 11:32 PM
