Compression Questions........pred compression....
Old Dec 11, 2004 | 06:01 PM
  #21
omahapredator's Avatar
Default Compression Questions........pred compression....
UPDATE....do not install HPD valve springs in your machine!!!!! i repeat DO NOT!!! talked to doug and he is pulling mine out and putting in stock springs...they are junk according to him!!
Old Dec 11, 2004 | 07:51 PM
  #22
NJRaptor419's Avatar
Ernie, a higher compression(higher dome) will tighten up valve clearances too.
Old Dec 11, 2004 | 08:57 PM
  #23
Ernie660R's Avatar
This is true, but the piston manufacturer should have allowed for the piston to valve clearance. I am not saying you are wrong, it is always a good thing to check everything.[img]i/expressions/face-icon-small-smile.gif[/img]
Old Dec 11, 2004 | 09:25 PM
  #24
how do you set the piston clearance??? i know how to check it but what if you have to little or too much?
Old Dec 11, 2004 | 11:05 PM
  #25
Ernie660R's Avatar
Thumb of rule is to have at least .080 thousands between the valve and piston. This is after putting some clay on top of the piston then rotating the crank shaft two times. Then check the clearance by cutting away half of the clay around the valve relief area of the piston. The distance measured between the top of the clay and the top of the piston is your clearance.
Old Dec 11, 2004 | 11:45 PM
  #26
how dop you fix it if it's off??? say you have too much ...than say you don't have enough clearance!!
Old Dec 12, 2004 | 12:14 AM
  #27
Ernie660R's Avatar
You can never have too much clerance. If you lets say .050 thousands then you know you have to fly cut the valve relief area .030 thousands to have the proper clearance.
Then lets say you have .090 thousands or more then you are fine. [img]i/expressions/face-icon-small-smile.gif[/img]
Scooter's Shop
Oct 9, 2015 02:09 PM
CosmoM
Sep 21, 2015 04:57 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
Steeldon
Sep 9, 2015 09:38 AM
