K&N?
Old Dec 17, 2004 | 07:21 AM
Hozed's Avatar
Default K&N?
if u use and prep a k&n properly you shouldnt have any problems... u need to make sure the ENTIRE filter is cover with oil and that u clean it often. in sandy/dusty conditions it probably needs to be cleaned every ride depending of course on how much you ride.
Old Dec 17, 2004 | 08:07 AM
elkbow's Avatar
Default K&N?
what i'm doing is using the pre-filter that comes on the stock polaris filter over the top of my K&N, fits perfectly, keep some of the larger stuff out......you have to clean the k&N's as well as any other filter on a regular basis.....
Old Dec 22, 2004 | 11:24 PM
GoingVirtical's Avatar
Default K&N?
I to was using the factory cover over my K&N. BUT, one day while cleaning the factory pre-filter, (this may sound sick) I put my mouth up agianst the nylon pre-filter and sucked in hard. I found that it resisted air flow. I put it back together with just the K&N to test my theory and gained about 8mph on top end. No Joke. I have alot more power in all ranges.
"03" sp 600
Old Dec 23, 2004 | 01:23 AM
elkbow's Avatar
Default K&N?
"03" sp 600
After reading your message, I had to try....not experiencing the same thing here. It did feel like it draws better one way than the other....but is pretty much free flowing on mine....
Old Dec 23, 2004 | 04:24 AM
  #15
jimmypsp700's Avatar
Default K&N?
I use the Outterwear's pre filter on mine, looks to be the same as the stock one that I keep as a spare.
