Nerf Bars With Heel Guards
Old Dec 17, 2004 | 05:08 AM
duneaholic's Avatar
Default Nerf Bars With Heel Guards
Does anyone have these on their Scrams or Sports? My wife wants some but want the heel protection. They are kinda pricey so I was wanting to see if anyone had them before I laid down the cash. Thanks.
Old Dec 17, 2004 | 07:43 AM
Troyer23J's Avatar
Check my pics.
They weren't too bad to install. I had the cut the front bars on them, weld pegs on my frame, then slide the bars on.
They are AC Pro-Pegs for a raptor. I got them from www.gopartsdirect.com that was the cheapest place i found them.
Old Dec 17, 2004 | 09:56 AM
duneaholic's Avatar
Yours was the first place I looked. I wasn't sure if that was part of the Polaris frame or the Honda frame. Do the nerfs bars have a place for a round pegs to slide onto. I looked at some on ebay and they looked like yours did. But they were for I believe a Banshee. It looked like they supplied some round pegs to install after you removed the stock foot pegs. I'm not sure how Banshee stock pegs are configured so I was just guessing. On my Scram I used a steel bar of 3/4 conduit to connect the two sides together and clamped the conduit to the bottom of the frame. I looks like you couldn't do that cause of the modded frame so I'm guessing again that you had to weld the pegs to the frame. One more question. How did you weld the heel guards(they are aluminum?) to the steel frame. I'm no welder but I didn't know you could weld aluminum to steel. Thanks, Shawn.
Old Dec 17, 2004 | 10:03 AM
Troyer23J's Avatar
The bars are made so they join together in the front, you have to cut that out, because they wont fit with the polaris frame. I had to weld pegs in the front that the bars would slide on to, because of the honda frame. You could use the conduit like you were saying, and connect it that way. In the back, the bars do come with brackets, but, I made my own, and welded them to the frame. So on each side of the bike I have two pegs that come out, and the bars slide right on. You can see in my 2nd and 3rd pics that the right bar also has a thing in the back to bolt to the frame, I just welded a tab to the frame for that.
As far as welding on the aluminum, I didnt, they just slide on and bolt in place. I drilled a hole through each bar where it slides on, and bolted it through the peg, and one through the tab I welded on.
Putting the bars on was actually alot easier than I thought it was going to be when I took them out of the package. I think these are the best looking bars out right now too, I love em.
Old Dec 17, 2004 | 10:07 AM
duneaholic's Avatar
What about the Weld on the heelguards to the frame?
Old Dec 17, 2004 | 10:09 AM
duneaholic's Avatar
Nevermind I see where you welded a tab and then drilled the hole. I didn't see that the first time.
Old Dec 17, 2004 | 04:10 PM
Troyer23J's Avatar
yeah, just drilled and bolted.
Old Dec 17, 2004 | 05:26 PM
talonhawk's Avatar
I've got the AC pro peg nerf bars on my 99 TB 250!
Old Dec 17, 2004 | 05:31 PM
duneaholic's Avatar
Hey talonhawk. Are those for the Banshee? They look really good and look like they fit just like mine. Did you have to cut off the foot pegs and weld a round peg to mount the peg end of it?
Old Dec 17, 2004 | 08:01 PM
talonhawk's Avatar
Mine are Raptor nerf bars and yes I did cut off the square pegs but I bolted
and spot welded the new round pegs to the frame.
Valder
Nov 28, 2020 07:38 AM
wendal
Sep 7, 2019 06:46 AM
badgerboy1
Sep 26, 2017 06:11 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
