Unbiased polaris 800 power?
Old Jan 12, 2005 | 12:12 AM
  #61
BryceGTX's Avatar
Default Unbiased polaris 800 power?
Hey cc1999. Do you plan on replacing the ECU for the EFI control? I am sure these EFIs run open loop. Seems you will need a different map to get the full gain from a pipe. I noticed that the Dynojet has ECUs for controlling the EFIs on Polaris quads.
Old Jan 12, 2005 | 01:25 AM
  #62
cc1999's Avatar
Yes, I am planning to get an ECU, what I am not sure of, is if the ECU that states its for the 700EFI will work on the 800 or would Ineed one specific for the 800. I need to do do some more reserch.
Old Jan 12, 2005 | 09:04 AM
  #63
SHOTGUN's Avatar
CC1999, I didn't mean to seem like I was down grading the dyno results in any way, just throwing in my opinion about the crank dyno, and as you said there is a big lost in hp.
Old Jan 12, 2005 | 01:19 PM
  #64
BryceGTX's Avatar
Hello SHOTGUN. You have a valid point about crank HP numbers. Especially with a power curve. It is a good way to compare engines. The clutching and wheels can be played with to make the mechanicals more effective. Although CVTs are not as bad as most people think. From what I have read, they are between 90 and 95% efficient, which is as good as a geared transmission. Maybe more of a problem is the rotating inertia of the clutches and belt can be quite high. This may tend to slow the acceleration.
Old Jan 12, 2005 | 06:45 PM
  #65
cc1999's Avatar
Does Polaris have separate websites for other country's, I know I have found power numbers on other brands that way. You somtimes have to convert the the numbers over to HP, but I bet those would be crank numbers rather than RW.
Old Jan 12, 2005 | 07:05 PM
  #66
BryceGTX's Avatar
Hey cc1999. Excellent point; worth checking into. On the other hand, there is a dyno company (can't remember the name) that makes small water dynos for use with snowmobiles that connects directly to the crank while it is in the chassis.
BryceGTX
Old Jan 12, 2005 | 09:03 PM
  #67
polaris5610's Avatar
Some links... [img]i/expressions/face-icon-small-smile.gif[/img]
Polaris- Australia/New Zealand
Polaris France
Polaris Italia
Polaris Britain
Polaris Switzerland
Polaris Spain
Another one?
Polaris world wide
Old Jan 12, 2005 | 09:56 PM
  #68
propolaris's Avatar
The 800 is by far the most powerful atv in production. after riding the BF. ther is no way i would pick it over the 800. I love the motor on the BF but that is it. There was no question after riding all three machines the 800 is more stable, like a rock, 800 is built 10x tougher than the imports, beefier parts thru out. more weight, but you would never know it from its power. great stock tires, stainless steel brake lines, proven motor. Go USA.
Old Feb 1, 2005 | 11:35 PM
  #69
cc1999's Avatar
I got the Dyno results today, these results are from the quad bone stock form
it has a peak HP 34.58 HP at the rear wheels
max torque = 56.48
top speed on the dyno was recorded at 71 MPH
Actual real world top speeds are normaly about 4-6 mph slower than dyno testing indicates
No surprises here same results as vegasdude had with his.
Old Feb 2, 2005 | 01:55 AM
  #70
zquad's Avatar
Hello all,
I finally got to ride my buddys polaris 800 the other day and I was impressed with how comfortable it rides. I ride a brute and most of us know the suspension could be better. I also got a chance to race him with my BF. Everytime we raced I would come out ahead, but the 800 is definently no slouch. It seems like a much more refined machine then my BF, and more stable at high speeds. With all that said, he still sees alot of my tail lights in drag races. It's all in good fun.............[img]i/expressions/face-icon-small-happy.gif[/img]
