Sportsman 700 2002 4x4 problem
Old 12-29-2004, 10:49 PM
polarisQC's Avatar
Default Sportsman 700 2002 4x4 problem
My problem is when im in 2x4 and im driving , the moment that my back wheel spin , for no reason my 4x4 ingage automatiquely . It make it very hard to control (my handlebar shake from left to right)
I bought it use , my dealer told me that he change the front gearcase.
Another point, when im in reverse even if i dont press my override buttom the 4 wheel are spinning (in 4x4 mode)
Im from Berthierville. Québec
im waiting for your help
it seam the dealer cant give me the good answer...
thank you
Old 12-29-2004, 11:07 PM
Bill35's Avatar
Mine did the same thing till I changed the front lub.Then never again.Talk to the dealer maybe theres a lighted wieght lub you can use.Mine only did it when it was very cold out
Old 12-29-2004, 11:47 PM
polarisQC's Avatar
80/90 in both
i dont think that what it is
help!!! im going to my job everyday with my fat 700!
Old 01-02-2005, 12:06 PM
polarisQC's Avatar
thanks...
Old 01-02-2005, 12:12 PM
Polaridoo's Avatar
Change the fluid in the front diff (actually its your 4wd hub). It calls for Polaris Premium on Demand Hub fluid or you can use ATF.
Old 01-02-2005, 08:19 PM
polarisQC's Avatar
new oil in front and rear gearcase!
but re engage all the time ....
plz help me to find a solution!
p.s.: sorry for my bad english!
Old 01-02-2005, 10:25 PM
Polaridoo's Avatar
Perhaps the switch for the AWD is defective or shorting to 'ON' all the time?
Old 01-03-2005, 07:31 AM
Bill35's Avatar
My moneys on the lub...drain the 80/90 out of it and but in the right lub...
Old 01-03-2005, 09:37 AM
Bubs's Avatar
I HAVE THREE BUDDYS THAT HAVE 04.5 AND THEY HAVE THE SAME PROBLEM,ONE GUY TOOK IT IN AND THEY REPLACED THE WHOLE FRONT END BEFORE THEY GOT IT FIXED.NOW THE OTHER TWO ARE DOING IT AND THEY ARE OFF WARRENTY.FROM WHAT I UNDERSTAND THE PARTS THAT INGAGE THE 4X4 WEAR PREETY EASY,I THINK THEY SHOULD OF STUCK WITH THE HUBS,IM GLAD I GOT A 04.
Old 01-03-2005, 04:01 PM
PatsPolarisPage's Avatar
What Bill35 and Polarisdoo said, Don't put Gear lube in the front, only the back. The front is either the Polaris Premium on Demand Hub fluid or use a ATF (automatic transmission fluid). I'd use a synthetic, but not sure if it's required.
I'm having a problem too, mine won't engage, I changed the fluid, but no luck.
Quick Reply: Sportsman 700 2002 4x4 problem
