scrambler steering problem
Old Jan 4, 2005 | 08:19 AM
Revshredd's Avatar
Default scrambler steering problem
The bad part samich is that if your boots were torn and it has already started pulling to one side, then the damage to the cv joint on that side has probably already been done. You may have to replace one of them. Make sure you service the side that wasn't pulling immediately.
Old Jan 4, 2005 | 01:07 PM
samich's Avatar
i will change the u joints to before i put the boots on thanks for the help guys
Old Jan 4, 2005 | 01:32 PM
Kudzu's Avatar
There is one other thing to consider. The front hubs have round steel plates that stick to electromagnets when the 4x4 switch is turned on. This causes enough drag to roll 6 pins out on the ramps of a six sided gizmo and lock the front wheels. Sounds complicated but is actually pretty simple and clever when you see and understand it. Anyway, these steel plates can themselves become magnetized, just like a screwdriver does when you rub it on a magnet. When the plate itself becomes magnetic, you can't get it out of 4x4, and one side can be affected without the other. The plates are cheap (about $5 each) and easy to change.
Old Jan 4, 2005 | 03:14 PM
samich's Avatar
hey thanks i will check them to i have had the hubs off before but did not check that i will refer to the manual an see what i need to do thanks
Old Jan 4, 2005 | 04:59 PM
  #15
Gopher500's Avatar
its your CV joint, ill tell you right now its gone. i already blew mine, thnx to a torn boot, and since i was so used to my kodiak (CV joints seemed immune to mud), i never payed attention. i had the same problem, yanks to one side on and off, replaced the shaft and everything (warranty covered it) and it cured it.
Old Jan 4, 2005 | 05:08 PM
  #16
Revshredd's Avatar
yeah, that's the bad part samich. You have to replace the shaft and all. That is why that part is so expensive! Especially if it ISN"T under warrenty as mine was. As gopher said, plan on replacing it because it is toast! [img]i/expressions/face-icon-small-sad.gif[/img]
Old Jan 4, 2005 | 06:25 PM
  #17
Gopher500's Avatar
i think it was around 250-300$ for the parts , not too enjoyable [img]i/expressions/face-icon-small-shocked.gif[/img] . i got lucky too, warranty ran out in 3 days
Cole Hadden
Jun 15, 2025 09:05 AM
maxjung
Jul 14, 2015 02:22 AM
maxjung
Jul 13, 2015 05:11 PM
1966F100
Jul 12, 2015 03:01 AM
Scottma518
Jul 10, 2015 12:42 AM
