sportsman 500 clutch shaking
My 1998 sportsman has a problem I can't figure out by looking in the service manual. At low RPM when the chutch is starting to engage & pull the belt, the clutch & shaft shakes & causes the belt to slap big time. It smooths out once the clutch is engaged & pulls fine. Could this be caused by the shaft bearing being bad? I have installed new buttons in the rear driven pulley & have proper belt deflection.
My local dealer has an idiot in the service dept. & is no help at all. I don't trust them & don't want to drive 100 miles to the next nearest dealer. Someone please help me.
Thanks,
deepassmud
Thanks,
deepassmud
