HELP! - I need Two-Stroke Experience.
Old 01-10-2005, 02:01 PM
EastTexasBoy's Avatar
Default HELP! - I need Two-Stroke Experience.
Watch out for the oil injection block off fix, On that particular motor when you buy a block off kit it includes a plug to put back in the hole the shaft of the oil pump left , see your water pump shaft runs your oil pump and without this plug your water pump shaft will drop causing water pump failure which = $$$$$$$$$$ Order a block off kit from hot seat !!!!
Old 01-10-2005, 02:08 PM
MX5SC's Avatar
EastTexasBoy: Thanks fer the heads-up. I'm really trying to avoid tearing into the case. [img]i/expressions/face-icon-small-sad.gif[/img] I was going to order a real block plate today.
Old 01-10-2005, 04:47 PM
Snowwolfe's Avatar
I am not sure if 40 to 1 is correct or not. It certaintly doesnt need any more oil than that.
Old 01-10-2005, 08:20 PM
BAlaska's Avatar
My 97 Sportsman was dying on me earlier this winter. come to find out I had about 1/2 gallon of water in my fuel tank. Now it runs great.
Oh yeah, I had to also retard the timing, because the damn thing pinged too much with regular fuel. Now it runs very smooth.
  #15
Old 01-10-2005, 08:50 PM
jamag's Avatar
i race my 250 trailblazer real hard through some pretty nasty conditions, and have never had any probs. with running 40:1 ratio, i even think 50:1 would work, but 40 :1 is easy to remember, 16 ozs. of oil to five gal of fuel....
bigred20653
02-06-2016 01:54 PM
jankerstien
09-21-2015 03:09 AM
Thor
07-19-2002 08:28 PM
Mxracer98
06-06-2000 12:01 PM
trx430ex
12-15-1999 08:49 PM
Quick Reply: HELP! - I need Two-Stroke Experience.
