Reserve not working
Old Jan 11, 2005 | 12:13 AM
DGpolaris2346's Avatar
Default Reserve not working
Well i went riding out in the snow today and while i was riding it ran out of gas. So i switched it to reserve and tried to start it and it wouldnt run. So i looked in the gas tank and saw that it was completely empty. Its not like i was riding all day on reserve i had the petcock on the on position. So if anyone has any idea on whats wrong let me know. Thanks
Old Jan 11, 2005 | 12:35 AM
2manytoys's Avatar
If the tank was empty then you probably were in the res position all the time. Because it has reserve does not mean it has a seperate tank. The fuel tank has a 2 level bottom. It is impossable for the tank to be empty unless you had it on res the whole time. The reserve switch on the Trailblazer is confusing. I have ran my tank out a few times before I figured It was opposite than I thought.
Old Jan 11, 2005 | 01:40 AM
Nope it wasnt on reserve the whole time i make sure of that everytime i go riding.
Old Jan 11, 2005 | 01:47 AM
jamag's Avatar
ive had the valve apart before and was wondering if it had been taken apart is it poss. to be put back together with the dial reading the wrong label? maybe ? did you buy the bike new?
just a thought, maybe stupid
Old Jan 11, 2005 | 02:07 AM
jimmypsp700's Avatar
Look inside the tank from the fill cap and the tube sticking up from the bottom of the tank (rearward fitting) should be much longer than the one towards the front of the machine. use a trouble light or flashlight under the tank to aid in viewing.
If this is not the case Pull (unscrew) the fuel fittings out and switch them around, they may have been installed in the wrong place from the factory or the previous owner.
Old Jan 11, 2005 | 02:49 AM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
I had the same thing happen to me last time I went snow riding around the neighborhood.
I almost ran out of battery trying to start it on reserve. (scrammy)
I finally decided to check the ****,,,,and sure enough,,,,,it hadnt clicked all the way into reserve. In otherwords,,,to the eye,,,it looked to be in the right postion,,,,,but it hadnt actually turned all the way to reserve (on the tank side of the mechanism).
be sure it is engaged all the way
Old Jan 11, 2005 | 02:10 PM
The gas tank was completely empty. Ill do what jimmypsp700 said to do later on today.
Old Jan 11, 2005 | 07:51 PM
Alpine2's Avatar
I had the same thing happen to me . just take the petcock off and readjust it no problem it just slipped inside.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
