scrambler dilema
Old Jan 11, 2005 | 02:42 AM
lukaka's Avatar
Default scrambler dilema
I'm hoping the title gets some of you scrammy guys to help me out. My problem, I have aquired a 99 400scrammy 4x4 that has been converted into a 4x2. I haven't tore into it too much yet but I know the bottom is shot because I do have the jug off and the crank has way too much slop. I'm wondering what will match up. For example, can I just get the bottom off of any 400( sportsman, scrammy, explorer) and have it match. Or even can I get the bottom off of an old 350 and have it work. Hope everyone understands what I'm trying to say. Any info is much appreciated.
Old Jan 11, 2005 | 02:47 AM
jimmypsp700's Avatar
The sportsman 400 is a four stroke but the older xplorer 400 2 stroke MAY work, not sure.
Old Jan 11, 2005 | 04:44 AM
lukaka's Avatar
my bad, I was thinking they put the 2 stroke in the older sportsmans too. What of the 350's, any idea if they have the same stroke as the 400's. I may even be abe to just replace the crank if I find one that will work. I don't know how bad the case is yet, hopefully new bearings and it can still be used.
Old Jan 11, 2005 | 09:30 AM
scramblerXrated's Avatar
you might try and go to www.partsland.com and cross-reference some part numbers from other models.
at least see if there are models out there with what you need to look for.
just an idea.
X
Old Jan 11, 2005 | 09:35 AM
thewayout420's Avatar
give rick ritter at rcr a call,he has rebuilt cranks for $125 i think.even if you buy a bottom end who is to say it isnt on its way out?id rebuild it all and have the peace of mind knowing everything is fine.
Old Jan 11, 2005 | 11:11 AM
CED's Avatar
CED
I will second what 420 said,Ritter Cycle.
Old Jan 11, 2005 | 08:25 PM
ftwflh's Avatar
1994-98 400 Sportsmans were 400L 2strokes. Do the crossrefferances at partsland.
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
