AWD NOT WORKING
Old Feb 6, 2014 | 05:25 PM
  #21
Originally Posted by mike beck
I tried what u said nothing....so I took both small Greywires from hub and put them on red and white circuit blades got awd now what is your opinion on this??? Does that mean awd switch is bad or switch in shifter is bad?? Wondering if I could just put toggle switch on two grey wires so I can switch from two wheel to 4wheel??? Your thoughts??
More than likely the shift box switch(about $130) is the problem along with worn out shift box parts. It sends the power to the awd button and light then to the front wheels.Basically you've bypassed the switch and button. People have done it and posted on the forum. If you want to run a toggle that would be better imo and not have constant power to the hubs.
Old Feb 6, 2014 | 05:39 PM
  #22
mike beck's Avatar
Bulb is blown do u think if I changed bulb and shift box switch it would go back to normal?? Or is toggle sufficient?? I have belt from my 700 on this explorer 400 that might explain why shift box parts got worn cuz it does shift hard..
Old Feb 6, 2014 | 05:49 PM
  #23
If you want to spend the 130 bucks,PLUS as I mentioned it may be worn parts in the shift box that that are not allowing the switch to operate.Shift box wear was a normal problem as they got older. If you have awd now and can run a toggle,that should be ok. The choice is yours. Get the right belt too. #3211077
Old Feb 6, 2014 | 06:18 PM
  #24
mike beck's Avatar
Thank u so much opt you have been HUGE help..reason I asked about small Greg wires I cuz on this forum I haven'theard of anybody doing this..and was wondering if iI would fry something being that those wires from hub are very small gauge... I meant Grey not Greg...thanks again....
Old Feb 7, 2014 | 05:59 AM
  #25
mike beck's Avatar
One of front hubs was dry I didn't have any polar hub oil and nearest dealer is hour away so I put some 10-30 in it for now u think ok temporarily??
Old Feb 7, 2014 | 08:58 AM
  #26
TLC's Avatar
TLC
If you are stuck you can use Automatic Tranmission fluid "Type F" according to my Clymer Manual .
Old Feb 7, 2014 | 02:16 PM
  #27
user493's Avatar
Moto Psycho
10W-30 is too thick.
hugemoth
Jul 20, 2020 03:28 AM
rcappie4
Jul 18, 2015 07:51 AM
timster911
Jul 13, 2015 01:57 PM
J-Mack
Polaris Side by Sides
Jul 4, 2015 04:19 PM
bikedad3
Jul 2, 2015 02:15 AM
