Worn Cam?
Old Jan 20, 2005 | 05:30 PM
lds's Avatar
lds
Default Worn Cam?
I was just reading another thread about the 2000 sportsman having problems with the cam wearing causing the vehicle to be slugish at full throtle. I have a 99 6x6 big boss (500) that I just got back from the local polaris dealership. It was running rich so the dealership put a new needle in the carb and adjusted it. The big boss no longer runs rich and actually runs and idles really good. However, it is sluggish from 3/4 to full throtle. Is this still a carb problem or could the cam be worn? Also, is there any way to tell if it is a carb problem or a cam problem?
Old Jan 21, 2005 | 12:32 AM
fishslab's Avatar
Default Worn Cam?
On a unit as old as yours that may have seen some real work, I would bet your problem is in your clutches more than anything. Worn out primary and secondary springs can give you the symptoms you are reffering to. If you look into it get a new belt if yours has got some time on it as well. From what I hear a worn cam will give you wierd popping and throttle response with low power.(almost like a rev limiter) Just what I've heard on here though. I'm no expert, but these are my guesses.
Old Jan 21, 2005 | 10:46 AM
lds's Avatar
lds
Default Worn Cam?
I did have the clutches, the belt and everything else replaced concerning the drive. All of the work was done by the dealer to the tune of about $1100.00. The rev limiter that you mentioned is exactly the sympton that it has. However, it does not pop or make any other type of wierd noises.
Old Jan 21, 2005 | 12:56 PM
omahapredator's Avatar
Default Worn Cam?
you might try a size or 2 bigger on the main jet .... JMO
Old Jan 21, 2005 | 06:41 PM
ftwflh's Avatar
Default Worn Cam?
Unhook the rev limiter by finding the black wire coming from it and unplug it.This will disconect it but you will still need to hold the button for 4x4 in reverse.
Old Jan 24, 2005 | 09:51 AM
lds's Avatar
lds
Default Worn Cam?
Does the 99' have a rev limiter and if it does, where would I find it?
Old Jan 24, 2005 | 10:02 AM
lds's Avatar
lds
Default Worn Cam?
Sorry for the last post. I checked my manual's wiring diagram and I found a speed limiter. Is this the same as a rev limiter?
Old Jan 24, 2005 | 11:39 PM
ftwflh's Avatar
Default Worn Cam?
Try unplugging the black wire and see how it acts.Yes this is the same thing.
merryman
Jan 19, 2016 04:29 AM
mbkirk
Aug 14, 2015 08:20 PM
mbkirk
Technical and How-To Articles
Aug 14, 2015 08:12 PM
Bkeb
Aug 12, 2015 12:45 PM
willday08111217@gmail.com
Aug 1, 2015 04:05 AM
