Magnum Fuel Lines
I just got a cheap ($100) Polaris Magnum, needs some work, starting with the fuel system. Does anybody have a diagram of the fuel line routing? Polaris' parts manual leaves a lot to be desired, doesn't show where fuel lines run, just where they start. I haven't dealt with these Mikuni flat slides, all I have played with are round slides on sleds. Any help would be appreciated.
Chad
Chad
Take the money you saved and invest in a factory service manual. Gotta believe at 100 bucks, you'll be working on more than just fuel lines.
I think it's a 97, I will check when I get home, thanks RobRuf
$100 plus work on a buddy's sled is actually what I paid. He would have given it to me but it has 4 new tires that he needed to cover some of the cost on. It ran and he rode it a couple years ago, then sat in his garage when he bought a new one, now has the jets plugged, and I question if it was plumbed correctly. I'm sure it will be a good 4-wheeler, just sorry it wasn't a 2 stroke.
Only things I know it needs are the new tires put on, a new chain (rusty), and the shifter adjusted (won't lock into low). Other than that it needs a typical "been sitting for a while" clean up, new plug, oil...
