Polaris struts
Old Jan 26, 2005 | 10:24 PM
ktk's Avatar
ktk
Default Polaris struts
What's the option when the front struts are leaking oil and need to be replaced? Does anyone rebuild them or are they a throw away and replace? I noticed something is probably going to have to be done soon. FWIW, a 94 400L is the quad in question, kind of an oddball model.
Old Jan 26, 2005 | 10:28 PM
Wolverine350R's Avatar
seems to be pretty much toss'em. stock replacements are fairly cheap
Old Jan 26, 2005 | 10:41 PM
ktk's Avatar
ktk
Thanks, I mean to ask as well is this a do it yourself or should it be left to an expert? I'm mechanical enough to do it. Do I need any special tools?
It's my dad's quad but I think he's gonna have to do something. I was breaking his engine in and they (struts) are terrible and leaking oil badly. Is this something I can buy ebay or would the money be spent better somewhere else? He's not going to want to spend any money being I just rebuilt his engine for him and he wasn't really wanting to sink that much into it to begin with.
Old Jan 26, 2005 | 11:50 PM
I think you could pretty easily do it yourself. I believe you just have to unbolt it at the top up under the fender, and then I think there is like 2 bolts at the bottom on the steering knuckle that may only need to be loosened for the strut to slide out.
Not sure about e-bay, if you type "Polaris struts" someone is selling a bunch of Kimpex for ~125 a set, but you would have to be careful of the size. I would check at a dealer for the factory parts, I read in Dirt Wheels once that they were only like $50 each.
Also if you do it yourself you might want to tie up the spring before loosening the top, there may be some energy stored in them.
Old Jan 27, 2005 | 12:00 AM
ktk's Avatar
ktk
The spring was my concern if I am understanding them right.
I didn't realize they were that cheap. I checked at Ronnies.com and they listed for $100 apiece. I was surprised to see them that low. I checked out Works but they didn't list anything for that model so it's probably an oddball size.
I guess I'll ask my local mechanic next time I see him. Still can't get that #$#!@ carb right. Cannot get it to idle. Everything else is fine but it will not idle.
Old Jan 27, 2005 | 12:37 AM
for idle make sure your ETC on the throttle is adjusted right. I think that ATV would have one. If its not adjusted right, the atv will idle with you pushing the throttle a little, but when you let off it will die. My Pred did that and it was driving me nuts till i realized what it was.
Old Jan 27, 2005 | 04:55 AM
Lukester's Avatar
What and where is the ETC? I think I know but would rather be sure.
Old Jan 27, 2005 | 07:31 AM
jimmypsp700's Avatar
I beleive thats the Electronic Throttle Control located at the thumb throttle.
Old Jan 27, 2005 | 08:23 AM
GE4x4's Avatar
Works struts These should work for your 400L.
Old Jan 27, 2005 | 10:30 AM
BubaHyde's Avatar
These are very cost effective. And probably a little better than the factory units.
http://cgi.ebay.com/ebaymotors/ws/eB...category=43974
