Polaris struts
Old Jan 27, 2005 | 08:50 PM
Wolverine350R's Avatar
Default Polaris struts
the actual ETC in inside the thumb throttle assembly, it kills the machine if the throttle gets stuck in the carb or the cabling. Adjustment on all the ones I've messed with is right in the cable portion that is up on the handlebars.
Old Jan 28, 2005 | 04:24 AM
Lukester's Avatar
jimmypsp700 and Wolverine350R, Thank you for explaining what the ETC is. I thought that's what it is. I haven't had a problem with mine. I have adjusted some cable stretch out of the throttle at the adjustment under the rubber boot in the cable by the throttle - but left just a little slack. I would hate for a branch to pull my cable out as when I pull it out the throttle increases pretty high.
Pull up on your cable and you might see what I mean.
Old Jan 28, 2005 | 11:34 AM
dailyrider's Avatar
I have a setup that uses marvin shaw shocks. Look at the red bike in my photo's
Old Feb 12, 2005 | 05:14 PM
silverbullet2005's Avatar
hey KTK, I looked on www.polarisoemparts.com and they have the factory replacements part number 7041451 which are $99.99 at the dealer for $83.32 each. you can find the part you need on the diagram then punch it in and it gives you your cost on it since they discount the parts on this website.
Old Feb 12, 2005 | 06:12 PM
  #15
ktk's Avatar
ktk
Thanks for looking that up for me. I appreciate it.
Old Feb 12, 2005 | 11:38 PM
  #16
homdaddy's Avatar
hey daily iwant that setup how about hooking me up
Old Feb 13, 2005 | 01:57 AM
  #17
elkbow's Avatar
I looked up the info on the strut, the earliest i could find were for a '98 400L, the first cost is retail, the second from polarisoemparts:
2201460
STRUT,KIT,FRONT SACHS,ST-**
$99.99
$83.32
Old Feb 15, 2005 | 04:35 AM
  #18
PhilFixit's Avatar
The Kimpex Pro Gold struts go for around $125, and they do give a better ride than the stock ones - IF you get "good" ones. I put a set on my GF's TB and they've been fine, but I've seen them start to leak out of the box, too. If you buy the Kimpex, get them from a dealer that will honor the warranty, so IF you get a bad one, it's taken care of.
The Fox's are about $240 a set and are rebuildable/revalvable. So are the Works, but they are around $440 a set.
Old Feb 15, 2005 | 10:50 AM
  #19
thewayout420's Avatar
you cant get the works struts for less than the fox struts[img]i/expressions/face-icon-small-smile.gif[/img]
Old Feb 15, 2005 | 04:25 PM
  #20
homdaddy's Avatar
i ve got the works on mine . igot one of the first set they were 350 and they were valved to weight and riding style . and you can adjust the pressure they ve been running strong for 4years with no problems and a much nicer ride
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
maxjung
Jul 13, 2015 05:11 PM
