sportsman 4wd problem HELP!!!!
Old Feb 5, 2005 | 07:36 PM
FireCaptainSteve's Avatar
Default sportsman 4wd problem HELP!!!!
I was out riding in the snow today. And my friends 2001 500 Sportsman was only turnnig 3 wheels in 4 WD.
Something is wrong! Broke or out of adjustment. HELP, where do we start ????
Old Feb 5, 2005 | 07:45 PM
brainiac213's Avatar
try these steps in this order:
1.) check hub fluid
2.) check electrical connections
3.) check the armature plate...most likely is the problem.
Old Feb 5, 2005 | 08:51 PM
Is there anything that needs to be adjusted? Whats up with the magnets in the front end? what do they do? do they need adjusting?
Old Feb 5, 2005 | 09:02 PM
RobRuf's Avatar
I had the same thing happen to me about a month ago.... I changed the hub fluid and flushed it, cleaning the magnet on the drain plug with each flush (3 in all) Man the mud and junk in there... Well after the change all was better, I would recommend the same. Its a easy step and chances are that your problem
Old Feb 6, 2005 | 12:31 AM
elkbow's Avatar
Hub fluid is most likely your problem....
if you ride alot, change the fluids on a regular basis, more than yearly as polaris suggests.....people have a tendancy to change the engine oil and filter, but neglect the differentials....
Old Feb 6, 2005 | 02:22 AM
tyler711's Avatar
Also try a search on these forums, this problem pops up here every few days. I still think that someone should make a nice sticky.
Old Feb 6, 2005 | 07:47 AM
Well I guess the first thing will be the Hub fluid change.
Do these hubs ever break?
Do the magnets need adjustment?
Old Feb 6, 2005 | 06:57 PM
tyler711's Avatar
As far as adjustment, the castle nut in there needs to be the right torque. I forgot what the correct torque was, maybe 12 inch pounds? Don't listen to that, its a guess. That needs to be torqued right or it won't engage/disengage properly.
Old Feb 7, 2005 | 08:05 PM
Thanks for all the help guys. I found the problem. I took it apart and the hub cluth was not in right and its destroyed. I will need a entire new one.
Old Feb 7, 2005 | 09:20 PM
tyler711's Avatar
Glad you found the problem, but sorry you need to shell out some cash. When you get the pieces you need, make sure you get everything in there in the right order and you will be good to go!
skittero
35
Mar 1, 2019 12:39 AM
yellowpolaris
Jun 21, 2015 11:13 AM
UPLou
Jun 7, 2015 09:42 AM
May 27, 2015 11:15 AM
PolarisPower500
May 17, 2015 02:28 PM
