scrambler ground clearance
you can put 12 inch rims and tires set on. that will give you more clearance. just make sure you get the tire sizes right. i havent had any probs with the regular clearance, unless yer gittin into the deep ruts from big ute trails. (just stay high side)
X
X
I have a '00 scarmbler 500 4x4, and I have not had any trouble with it mudding. It even sits lower since I put ITP wheels and Maxxis Razzar Tires on it. I even race harescramble races with it and i have not had a problem with it yet.
I would assume that my xplorer has a similar ground clearance, it is also a chain drive. I find that in the real deep soupy mud (>2 feet deep) it does fine, amazingly well actually. It is only in the more solid stuff that the back axle begins getting caught up. I have gotten beached many times falling in to the ruts and having all four tires in the air. But it is light enough to just lift out. I have seen some people weld like spokes sticking off of the axle to keep moving when they get bottomed out.
Tyler
Tyler
exmotocrosser
Sep 13, 2019 06:12 AM
