Front suspension metal lifting spacers?
Old Feb 12, 2005 | 11:58 PM
2manytoys's Avatar
Default Front suspension metal lifting spacers?
Silver,
I would be interested in the 2" spacers.
Old Feb 13, 2005 | 10:54 PM
Bill35's Avatar
Silver if you cut the OD at 2 1/2 in what is the ID.Im thinking of making a set to.
I did just get done making a set of 1in spacers for the front for the bigger tires im getting.If anyone wants to see the spacers let me know...Bill
Old Feb 14, 2005 | 11:25 PM
silverbullet2005's Avatar
Bill I just posted some pics of the spacers and the inner diameter needs to be 2" to allow for the strut cartridge. make sure the spacers are very square though cause the spring is flat on the bottom and rests on the spacer. when I make mine I chuck them up in a lathe and then cut them so all the cuts/surfaces are squared and perfectly smooth. I will sell you a set of them if you decide you don't want to fool with it but what were you making yours out of.
Old Feb 15, 2005 | 12:17 AM
Zbart1's Avatar
Hey there silver Bullet ………..I was wondering how much the spacers raised the front end or did they just make it stiffer?.. Do you think going from 1 inch to 2 inch spacers will give you another 1 inch in height or is there a diminishing return there?
I want to install a set on my 2002 500 ho since I don’t use a plow I was wondering if I need the 1 inch or the two.
I know that the springs really should be changed, but this mod is so easy and cheap I have to try it!
Nice pics by the way ………….I have a 72 XLCH sport that I just did a ground up on turned out great I purchased it new in 72 for 1950.00 …just can’t get rid of the old iron head!
Old Feb 15, 2005 | 11:25 PM
  #15
Bill35's Avatar
Thanks for the info Silver.I made a pair today at work Im hoping to get them on tomarrow.And did you raise your shock up an inch out of the strut boot? Bill
Bratman2
Aug 6, 2022 01:42 AM
Reactant
Mar 30, 2022 02:08 AM
carolinabomb
Jul 26, 2015 08:40 AM
Jkfx400P
Jul 6, 2015 10:04 AM
