Sand Tires - how important?
Old Feb 11, 2005 | 04:30 AM
Revlimiterdude's Avatar
Default Sand Tires - how important?
For those in the know - I need some assistance. I just bought some new wheels and was considering getting some sand paddles to put on them since I want to head out to the dunes. Problem is I also ride trails etc and really dont want to have to constantly change between wheels if I dont have to. I still have the stock Maxxis tires that came on my TLD Predator 500, how well do these work in the sand?
Am I being stupid by not putting on paddles? Please feel free to tell me, my feelings wont be hurt since my wife tell me I am stupid all the time! heheheheh
-Shane
Old Feb 11, 2005 | 06:46 AM
DubaiPolaris's Avatar
916 Reaper - Pure Evil Inside!
100% of my riding is dunes/sand. I just got some ITP SandStars, and the difference from the stock Maxxis are night and day in the dunes, espically in the soft sand. All the stockers want to do is spin and spin they will do all day in the sand. With the SandStars I get a good hook up and I am off. You will will have a better time in the dunes with a good set of paddles.
Thanks Chris
Old Feb 11, 2005 | 10:30 AM
duneaholic's Avatar
I would definately get some paddles. You will have a much better time. The razrs don't do real well in the sand. I got stuck a lot with them. I don't think it's that hard to change a set of tires. You can do it in under 10 mins. And that's taking your time. I've done it in under 5.
Old Feb 11, 2005 | 11:19 AM
fishslab's Avatar
If you have the means and oppurtunity get paddles for the sand!!! Stay away from Geckos. You will find arguements as to what type a mile long. Just do some searches on this site in the dune forums. You won't find a deffinite answer, but you will find lots of info.
Old Feb 11, 2005 | 12:21 PM
Pred500Rider14's Avatar
Well, if your going to gordans well dunes then i think you would get around fine, i did! but if your going to be riding the back dunes then you back end will be sliding down. I have paddles and its a lot easier to get around the back dunes though.
Old Feb 11, 2005 | 12:39 PM
RAJ's Avatar
RAJ
Just a thought.......find a set of rear rims and put the paddles on them, this is what I might do. I think the paddles would work better, on the dirt drags. You can find a good pair of paddles on e-bay sometimes cheap. They are a pair on there now rims and tires.
Old Feb 11, 2005 | 02:54 PM
Morewood's Avatar
It is definitely worth the ten minutes or so it takes to swap out your rear wheels when you switch between dirt and sand. Absolutely! (Of course, you want to just be bolting on, not changing rubber on the rim. )
Since you have a four stroke, I would also recommend getting sandtires up front....helps a lot with steering and float. Just depends on how flush you are! You can easily get by without the fronts.
Since you are from Oregon, I assume you will be riding Winchester Dunes...and going back repeatedly! The sand tires will help keep the RPMs down.....running knobbies in big sand dunes in hot weather can really heat up an engine, because you are at high rpm constantly.
Enjoy the dunes!
Old Feb 11, 2005 | 03:52 PM
thanks guys! Since I use the HIper wheels it takes a little longer to switch out the tires but I get your point! I will go for the paddles then - BTW - what is the deal with the Geckos? Those are the ones I was going to get?
-Shane
Old Feb 11, 2005 | 05:08 PM
duneaholic's Avatar
I think they are an ok tire just a little on the heavy side. I would personally go with Sand Stars. Inexpensive and hook up great.
Old Feb 11, 2005 | 05:56 PM
Morewood's Avatar
I would bet that the tire most used at Glamis, by the thousands, is the Sand Skate II. I have them on my Raptor and they are great for my sand riding (I like to corner). I have the Geckos on my Predator and I really like them as well. I found that I needed to run them on the soft side or they felt too stiff. I think they are a tad heavier than the SS IIs. The (new) Sand Stars seem to be very popular, but I have not tried them.
Any of these should do you well.
