throttle cable problems on explorers
Old Feb 13, 2005 | 09:27 PM
sirsinkalot's Avatar
Default throttle cable problems on explorers
myself and 4 others own explorers and all have problems with our throttle cables. we do know it is water creating the problem[throttle starts getting stiff and eventually sticking] and we have tried custom built cable,graphite lube,silicone lube,90 weight gear oil,atf,no lube,different routing,silicone on all joints to stop water from getting in but can't seem to solve problem.
we think it's due to the splitter butwe don't want to get rid of our oil injection.any suggestions would be appreciated.
Old Feb 13, 2005 | 10:13 PM
jeffro206's Avatar
you can take the splitter apart and clean it. then super glue it back together. also lube the lower cables good. make sure if these are on 400 exporers to clean out inside the oil pump housing too. i have a friend who has this problem with his mostly from water and mud. just gotta keep them lubed.
Old Apr 17, 2005 | 10:20 PM
snork's Avatar
ttt
Sjrpp
May 2, 2023 03:59 PM
Sjrpp
Nov 15, 2019 09:59 PM
Sjrpp
Jun 2, 2019 07:25 AM
Ramman1
Jun 16, 2016 09:07 PM
Sjrpp
Jul 5, 2015 09:04 PM
