breather hose update ?
Old Mar 23, 2005 | 07:56 AM
jimmypsp700's Avatar
Default breather hose update ?
With the 700/600 twins breather hose update the filter is omitted. In the manual it says damage will be done if you run without the filter in place.
Does this defeat the purpose? Shouldn't there have just been a slit cut in the existing hose /filter setup nearest the motor?
IMO it would be easier and better than replacing the hose/filter altogether.
Thanks,
Jim
Old Mar 23, 2005 | 08:45 AM
silverbullet2005's Avatar
is this update something you got in the mail, or just like a mod or bulletin?
Old Mar 23, 2005 | 12:58 PM
It was a polaris bulletin on 02-04 models with the breather hose having the filter in line from airbox to crankcase.
It can build up condensation in cold climates and freeze up causing a pressure build up. The fix was to install a new hose void of a filter with a small 1" slit to relieve the pressure if this was to happen.
Jim
Old Mar 28, 2005 | 02:52 AM
Bump....anyone?
Old Mar 28, 2005 | 02:55 AM
jeffro206's Avatar
jimmy,
would have to double check, but are you sure the manual isn't talking about the air filter - just calling it a breather filter?
Old Mar 28, 2005 | 02:59 AM
I would have to double check too but i think the owners manual (before update) mentions not to run without the breather filter too.
Could stuff get sucked in from the airbox into the engine w/o the filter there?
Old Mar 28, 2005 | 03:02 AM
jeffro206's Avatar
i guess i could suck something in to there, but probably only the condensation or oil vapors from the motor. don't think it would hurt anything tho.
Old Mar 28, 2005 | 03:18 PM
Originally posted by: jeffro206
jimmy,
Jeff,
on page 103 of the 02 700 manual it has a CAUTION box stating:
"Operation of your atv without a breather filter can cause engine damage."
it does say below with an asterask "Breather filter and hose 4 cycle engines with dry sump*" about checking it.
This is all under the Maintainance and Lubrication section.
the 700 is a pressurized wet sump , right? Maybe this dont apply but the diagram shown looks like the twin and this is a specific 2002 sp 700 owners manual.
thanks,
Jim
jeff,
one more thing the early 700's didnt come with a oil sensor. If i installed one from like the 03 or 04 model is there wiring to plug it into?
original oil sensor post
Sassinm1
Sep 30, 2015 04:23 AM
panicmanic
Sep 28, 2015 12:59 PM
bigred20653
Sep 19, 2015 02:11 PM
bvolks
Sep 13, 2015 12:57 PM
chewy78
Sep 8, 2015 10:37 AM
