250 explorer noise
Old Mar 23, 2005 | 04:22 PM
PL250RIDER's Avatar
Default 250 polaris explorer
I have a 2000 polaris 250 explorer, 2 cycle. when i am increasing the speed i hear a metalic tick,tick, which gets progressivly faster with speed. When i am coasting or going downhill the noise stops. It is hard to pinpoint , but it sounds like it may be coming from the clutch housing. Has anyone had a similar experience ?
Old Mar 23, 2005 | 04:36 PM
tyler711's Avatar
Mine make some really nasty noises when I apply gas, but I think that is from the chain. Not a ticking so much as a steady on/off grinding.
Old Mar 23, 2005 | 04:41 PM
DEARHUNTER's Avatar
I once had the same problem. I thought I was hearing things. could it be your hearing?????
Old Mar 23, 2005 | 08:36 PM
cmatthews24's Avatar
I have the same ticking on my 300 xplorer, a polaris dealership told me it's supposed to do that.
Old Mar 23, 2005 | 09:58 PM
PL250RIDER's Avatar
Thanks for the reply. I don't think they are supposed to do that, mine did not make the noise for the first three years after I bought it. It just started last October. From reading some of the responses today of others who hear noises, it could be in the clutch assembly. I guess when the weather warms up, I will take the cover off and take a look.
Old Mar 26, 2005 | 02:32 AM
fishslab's Avatar
Default 250 explorer noise
Two things come to mind. The buttons in the secondary could be shot. Or the bushings in the primary could be bad.
Old Mar 26, 2005 | 09:17 AM
PL250RIDER's Avatar
Thanks for the reply. I will check it out
Old Mar 26, 2005 | 10:19 AM
xcrrrrrr's Avatar
My wifes 2000 250 explorer makes the same noise. I lube the chain and it goes away. I think that it must be something to do with the chain tensioning system on these machines. Links seem to need lube very often.
Old Mar 26, 2005 | 11:31 AM
tyler711's Avatar
Well, I am replacing the chain on one of mine today. The newer one actually, but I drive it a lot harder than my dad does, so maybe that's why. I noticed that the noise is often the chain rubbing abainst the chain guide, an adjustment sometimes makes it go away.
Old Mar 26, 2005 | 11:36 AM
PL250RIDER's Avatar
Thanks for the reply, I will try to lube it more often and see if it helps.
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
firsttimerider
Sep 20, 2015 09:07 PM
