preddy 12.5 piston
Old Mar 27, 2005 | 01:20 AM
pooboy2's Avatar
Default preddy 12.5 piston
just wondering if anyone knows when they say, Designed to be used with stock engines, but has valve relief for high lift, long duration cam. do I need thos cams or I can add the cams later with out changing the piston?
thanks
Old Mar 27, 2005 | 02:09 AM
Oleman's Avatar
Designed for stock engines, pretty much says it all. Deeper valve reliefs will help avoid valve to piston contact if you were running a camshaft with more lift and duration. So if you add a cam later, you're good to go.
exmotocrosser
Sep 13, 2019 06:12 AM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
nastyblaster100
Sep 13, 2015 01:19 PM
