Checking old machine
Old Apr 4, 2005 | 09:28 PM
derf's Avatar
Default Checking old machine
I have a 96 scrambler (chain driven) i haven't rode in about 4 years. i would like to know what i should prep to ride this again. I changed the gas and fired it up fine. i need to change the tranny fluid what should i use? It was milky, and when in gear the machine wanted to go forward and stalls. Any other fluids i should change? i will hit all the grease fittings.
Old Apr 4, 2005 | 10:10 PM
20045SP500HO's Avatar
Change all fluids and make sure to grease the chain ALOT ... then ride it very easy for the first 2 or 3 hours ... you almost have to treat it as a new break in.
Old Apr 4, 2005 | 10:11 PM
nhmudbear's Avatar
You probaly check the counter balancer for oil, make sure if it has oil injection that pump is working. The transmission creeping could be belt engaging on clutch if high idle or clutch might have to be checked for clearance or need to be cleaned and serviced, both primary and secondary clutches.
Old Apr 4, 2005 | 10:12 PM
2manytoys's Avatar
If it creeps when you start it you might just want to ride it for a bit since it has been sitting to get the clutches worn back in. If it still does it then the clutch needs to be shimmed. You changed the injector oil, gas, fuel filter, injector oil filter, airfilter, gearcase fluid, grease all the fittings, lube the chain and have fun! You may want to change the belt also.
Old Apr 4, 2005 | 10:19 PM
derf's Avatar
what gear oil should i use? If i need to shim the clutch sould i replace them with a different spring color?
Old Apr 4, 2005 | 10:29 PM
2manytoys's Avatar
You can use the Polaris gear oil. 80-90w. Depending on the riding that you do, the performance you want or how agressive you want it to shift will depend on what color primary spring you want. If you dont care about any of those things then leave it stock.
Old Apr 4, 2005 | 10:30 PM
nhmudbear's Avatar
I think the counter balancer takes 10w30 motor oil approx. 3 ounces. To check spring when you hold it up both ends should be in straight line with each other, if not spring is bad. I do have a manual if you need other info, it is for xplorer 400 but some things might be the same.
Old Apr 4, 2005 | 10:47 PM
derf's Avatar
do you know where i put in the counter balance oil? I found the drain and dip stick for the tranny. should i use Mobil 1 oil in the tranny?
Old Apr 4, 2005 | 11:03 PM
nhmudbear's Avatar
The counter balancer has a dipstick located behind the pullstart and under carb, it has a slot for standard screwdriver and the top has a seraded edge for grip to grab with your fingers. It is not an easy place to get to, which is why it is easy to overlook during maintence.
Old Apr 5, 2005 | 12:26 AM
ftwflh's Avatar
After it has sat so long I would pull the belt cover and check for mice nests they like the vent tubes alot.
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
KimSJoh
14
Jul 18, 2015 07:20 PM
95wolv
Jul 17, 2015 08:13 PM
toonces
Jul 11, 2015 12:01 PM
D-Hagz
Jul 4, 2015 02:19 AM
