Bent Axel on Trail Boss
Old Apr 16, 2005 | 10:45 AM
seantx's Avatar
Default Bent Axel on Trail Boss
Originally posted by: thewayout420
the first one that broke was covered under warranty,the second one i bought and replaced myself,i think it was $169,after i broke the second one i replaced it with a team industries axle and dont plan to ever brake it..its really simple to change a axle,maybe 15-20 minutes worth of work..
Where did you get the axel? I was getting quotes of a lot more than that for a stock Polaris axel. Don't mind doing the work myself.
Old Apr 16, 2005 | 10:53 AM
thewayout420's Avatar
i bought the stock axle from here it was $169.99..i bought the team axle from hpd
Old Apr 17, 2005 | 12:31 PM
lslubecki's Avatar
I have seen a dura-blue on ebay a couple different times for the scrambler. You can straighten the axle yourself. You need two v-blocks a dial indicator and a press. Support the axle at the ends and dial indicate the center while you spin it. Mark the highs and press it there. Or support the axle at the bearing surfaces and measure the ends. Press the high spots. It takes time checking and rechecking measuring and remeasuring.
My riding buddies ride 400 4x4 scrammys and they ride and jump hard and never broke an axle.I have seen scramblers cartwheel and not break an axle. I have seen them bend but not break. I have nailed a tree hard at the right rear going fast and only bent the axle and not the wheel. Go figure.
Steve Lubecki
Old Deer Hunter
Sep 2, 2015 01:39 AM
Anomers
Aug 16, 2015 11:06 AM
Backwoods_badass
Aug 1, 2015 10:25 PM
Gnuters
Jul 19, 2015 10:03 AM
