Carb Help
Old Apr 26, 2005 | 02:12 PM
Prairie3604x4's Avatar
Default Carb Help
I currently have a buddy of mines 4 wheeler at my house I believe it is a 99 or so Polaris Scrambler 4x4 I think. Anyways it smokes and it doesn't idle very good. Now what I was going to do is take the carb off, and give it a good cleaning. How hard is it to take off the carb and clean it? Any kind of Info would be great!
Thanks!
Prairie3604x4
[img]i/expressions/face-icon-small-confused.gif[/img]
Old Apr 26, 2005 | 02:54 PM
scramblerXrated's Avatar
Default Carb Help
400? or 500 scrambler?
X
Old Apr 26, 2005 | 03:04 PM
Default Carb Help
It's a 400 2-stroke....
Old Apr 27, 2005 | 12:14 PM
oghma's Avatar
Default Carb Help
It isnt that hard basically pull the cap off that has the throttle cable going into it and the choke assembly and then the fuel line. The carbs are very simple to tear down and clean but the two stroke should smoke just not excessively. As for the idle part there is an adjustment screw that will help you with that. Turning it out makes it leaner and in makes it richer. Does it bog down when you are on the throttle? Or is the only problem when it is idling?
Old Apr 27, 2005 | 12:18 PM
Default Carb Help
It runs like a bat outta he** when your on the throttle, just seems to be idling badly.
Old Apr 27, 2005 | 12:53 PM
oghma's Avatar
Default Carb Help
You should be able to get the idle to smooth out with the adjustment screw. Not for sure what the stock carb is on your machine though. With Mikuni they have an air adjustment and an idle speed. The air adjustment is on the left side of the carb directly behind the slide chamber. and the idle speed is on the right side. In should increase the idle and out should lower it.
Old Apr 27, 2005 | 12:54 PM
oghma's Avatar
Default Carb Help
Sorry I was thinking the prairie, the scrambler does have a Mikuni carb on it stock.
Old Apr 27, 2005 | 12:56 PM
Default Carb Help
Great! Thanks for your help. I'll take a look at it and see what I can come up with.
GregM
Mar 6, 2018 06:53 AM
GregM
Jul 29, 2015 09:41 PM
ghost civic
Jul 27, 2015 03:15 AM
Aitch
Jul 21, 2015 09:40 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
Jul 8, 2015 02:16 PM
