EFI fuel pumps
Old Apr 28, 2005 | 10:57 AM
shaq700's Avatar
Default EFI fuel pumps
Anybody w/ EFI have any prob's with the fuel pump yet?!I washed my bike last night and when I put it away it was leaking coolant,so I pulled it back out, popped off the front cover, turned out to be the rad cap.While I had the cover off, I rinsed some mud away from on top of the struts with the bike running and went to back it in the garage again and it quit, wouldn't start at all.Turn the ignition on-no fuel pump!
This morning the pump works again!!??I'm wondering if water got into something?Even still it sees water out on runs.I just went through this 3 months ago when the pump quit and it got a new tank/pump
it started just like this,would work,quit,leave it overnight the pump worked again until finally it left my daughter and I on the side of the trail!!!! @#^&$*g POLARIS
Build date: March 18/04
ANY IDEAS!
Old Apr 28, 2005 | 12:02 PM
silverbullet2005's Avatar
My 04 700efi's fuel pump went out after only 11 miles and three days. the day I brought it home it died once, the second day it quit on me twice and on the third day my wife and I were riding back in the woods and it died on me and wouldn't restart. I had to have my wife ride her EFI back to the house and grab a tow strap to pull me back to the house. the whole thing was a pain in the butt but it did get fixed and has been fine since so I guess it's all good now.
Old Apr 28, 2005 | 01:55 PM
danjak's Avatar
When you pull the cover off to get at the radiator cap you have 4 fuses right above them, one of them is for the fuel pump and they are self resetable according to the parts manual.
Old Apr 28, 2005 | 02:31 PM
shaq700's Avatar
THANKS---That I heard about once before.Funny that water could trip the fuses, it was far from high pressure(Mr Clean autodry)and I had them out shortly after this happened.Tryed the bike again @ lunch today and it fired right up.
Thanks again!
Old Apr 28, 2005 | 09:12 PM
snosnake's Avatar
[img]i/expressions/face-icon-small-happy.gif[/img]3500 miles on my efi and never a problem yet!!!!
Old Apr 29, 2005 | 01:33 AM
DANO38's Avatar
My dealer told me the only Bad fuel pumps were in the '04.5's, and that some of the first replacement pumps are of the same batch per polaris, and should also be replaced... I think he said it might be a recall or something, I'm not sure.
Old Apr 29, 2005 | 09:34 AM
action450s's Avatar
From every polaris that I've worked on, it seems that the elsctrical systems are not sealed very well at all, If I were you id make some sort of cover for the fuse box to keep as much water out of there as possible. I have had to cut out many connectors on my freinds sprotsman 500, they are of poor quality and do not seal well at all, great place for corrosion to start and ruin a connection. Some I have soldered and heat shrunk, places where you need a connector, I've used a GM Bosch style connector (locks together and has the triple rib rubber seal). Another good thing to do with any ATV is to take apart each connector and apply dielectric grease. This will help seal out water, keeping water out in the first place is the most important step to not being left stranded by bad wiring!!!
PrairieDog126
Sep 12, 2015 06:53 PM
essonlaker
Sep 10, 2015 01:12 PM
MrTrashMan2U
1) Engine problems..
Sep 9, 2015 11:11 AM
gogogo
3) General Discussions..
Sep 8, 2015 08:49 PM
Elkaholic
Sep 6, 2015 02:44 PM
