Pred big bore HP?
Old May 8, 2005 | 02:07 AM
spyder6's Avatar
Default Pred big bore HP?
it says its useing U2 fuel, ive never heard of that
Old May 10, 2005 | 09:03 AM
omahapredator's Avatar
maddog that's dyno run i ssuposedly hardrock motorsports....an normal big bore will be in the mid 50's to lower 60's but you can go ta little more wild from there just depends on the $$ flow you have available it also has alot to do with what you did to compensate the big bore.... like bigger carb, bigger valves, ported head, what compression you run, what type of cams.....there are alot of variables in this ...but just a bigbore you supposed to gain 5-7 hp
Old May 10, 2005 | 05:40 PM
maddog56's Avatar
Thanks, the upper 50's to lower 60's was the answer I was looking for, just a ball park. I would really like to the see the valve train, compression, and carb/intake changes that yeild an extra 25 hp on the same bore though while still being naturally aspirated. You said it was from Hardrock motorsports, I read that on the dyno sheet but is that supposed to mean something?
Ernie is right, there is a noticeable dropoff and boost in the curve. Nitrous is my thinking, wonder how big of a shot? No big deal though, I got the basic info.
Old May 10, 2005 | 11:35 PM
nitrous rule of thumb... i would not exceed 20-30% of your HP that the engine makes on it's own....and Doug Nicholas told me that my motor with stock cams should be in the upper 50's if not low 60's, now if i add cams depending on which ones i will be well into the 60's
Old May 11, 2005 | 09:33 AM
  #15
stryder's Avatar
that dyno shows the pred running 11,000 rpms so their would be more mods then just the big bore kit. probably cams, springs, valves, port and who knows what else. I've heard that themost gotten from a pred motor is around 85 horse but that is a drag motor that's not made to last very long.
Old May 11, 2005 | 12:32 PM
  #16
Maddog419's Avatar
I agree with stryder & Ernie660R also look at the tire & size he was running. Looks like alot of info left out to get you to buy from them to me. To bad I like Jason anyway LOL. I just had him coat my piston and valves this week.
later
BYC
Sep 25, 2015 02:10 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
