Polaris primary spring part numbers
HPD uses the same part numbers as Polaris.
Polaris has them on there site as well, I can;t remeber the URL. But if you go online to there site, you can go to the accesary section and search for spring. It will pull up all the primary springs that Polaris makes.
hope this helps.
hope this helps.
Originally posted by: NBsportsman
SP70003 did you check out the Dalton blue?? It has a lower engagement than the polaris green or white and a higher shift out.....
I might have to get one of those blue Daltons and try it.
Big600twin
14
Jun 16, 2015 09:30 AM
