2000 scrambler new piston help
Old May 10, 2005 | 10:42 PM
extreme1's Avatar
Default 2000 scrambler new piston help
my scrambler started to loose compresion. I took it apart and let a machine shop bore it half over stock . ireplaced all caskets and bearings. they told me to go up 2 jet sizes . it was a 290 i went to a 310. stock says 230. i cant get it started without putting fuel dirrectly in the carb .when it does start it is real sluggish .what should i do know to aviod a dealer?
Old May 18, 2005 | 11:39 PM
supertuner's Avatar
if 230 is stock,i assume u would know - then 250 max. WHY is there a 290 jet in there? What has been changed from stock/what is leaking air?
Old May 18, 2005 | 11:43 PM
supertuner's Avatar
a jet size 6 sizes over stock on a stock engine indicates a major problem-and a possible source of your compression loss
Old May 19, 2005 | 07:53 PM
Budman650's Avatar
Mine is bored .010 over and has the hpd pipe and clutch kit and a 270 main jet.
MeadowlarkFarm
Nov 27, 2019 08:40 PM
nastyblaster100
Sep 13, 2015 01:19 PM
1000gade
Sep 9, 2015 03:35 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
Myronh
Sep 8, 2015 11:27 AM
