Brakes Squeak
Old Jun 15, 2005 | 12:29 AM
predatordude2's Avatar
Default Brakes Squeak
Forget the tube stuff. I have found out a long time ago to use the anti squeal sticker. It is a sticker that is aluminum. It like in the picture from Dennis Kirk.com and you should be able get it at a auto parts store. Bevel the edges. It could help. Also get the pad hot by dragging the brakes to burn the oil off. The last thing is replacing them.
http://www.denniskirk.com/jsp/produc...2&skuId=191268
http://www.moccsplace.com/images/brakes/primer.htm
Old Jun 15, 2005 | 01:09 AM
yellowrider250ex's Avatar
i have a new kfx400 and after i ride somewhere that has alot of dust or sand my brakes squeek. All i do is put some wd40 on my finger and put it on the roter and that makes it quit till i ride again.
Old Jun 15, 2005 | 03:46 AM
polarisbear500's Avatar
hey hardwood, yeah it is usually the rear brakes that make the noise or it is on mine at least. the rears are a never ending project to get to stop sqeaking, but i have found the technique of the water hose being sprayed in between the pads seems to help out the most...i don't know if there is a permanent fix though. PB500
Joe454
Nov 20, 2020 01:19 PM
EIF
Apr 20, 2017 07:15 PM
Whitelx1
Oct 2, 2015 10:55 PM
Ahtatu
Sep 28, 2015 12:14 PM
Canamaniac!
Sep 4, 2015 06:44 PM
